Setting quick preferences
The most commonly used Vectorworks, document, and interactive preferences are available for access from buttons on the Tool bar. Other commonly used settings, such as those for the clip cube, are similarly available. The Quick Preferences menu controls which buttons display on the Tool bar. The Data Bar and Edit Group Options list and the Zoom Line Thickness, Default 3D Render Mode, and Default 3D Projection preferences are enabled by default on the Quick Preferences menu.
Select the desired item to display its shortcut button on the Tool bar, if it is not already present. A check mark to the left of an item indicates that it is selected. Buttons display in the order the item was selected, with the first selected item the farthest left on the Tool bar. If the application window is resized, the Tool bar will truncate the display of buttons when necessary and replace them with ellipses on the right.
             Menu command  |
             Description  |
             Auto Display Detail Levels for Design Layers
             Displays the Auto Display Detail Levels for Design Layers preference button (see Document preferences: Display tab)  |
             Auto Join Walls
             Displays the Auto Join Walls preference button (see Vectorworks preferences: Edit pane)  |
             Autosave
             Displays the Autosave preference button (see Vectorworks preferences: Autosave pane)  |
             Black and White Only
             Displays the Black and White Only preference button (see Document preferences: Display tab)  |
             Dark Background
             Displays the Dark Background preference button (see Vectorworks preferences: Display pane)
             Displays the Data Bar and Edit Group Options list (see Data bar and edit group options)  |
             Display Light Objects
             Sets the display of light objects (see Vectorworks preferences: Display pane). The icon indicates the currently selected option.  |
             Sets the preferred 3D render mode, which is applied whenever a drawing is switched from Top/Plan to a 3D view (see Vectorworks preferences: 3D pane)  |
             Sets the preferred 3D projection, which is applied whenever a drawing is switched from Top/Plan to a 3D view (see Vectorworks preferences: 3D pane)  |
             Display Viewport Out-of-date Borders
             Displays the Display Viewport Out-of-date Borders preference button (see Document preferences: Display tab)  |
             Drop Shadows
             Displays the Drop Shadows preference button (see Document preferences: Display tab)  |
             Duplicate Tags with Objects
             Displays the Duplicate Tags with Objects preference button (see Vectorworks preferences: Edit pane)  |
             Project Sharing Options
             Sets the highlighting style for objects that are checked out from a shared project (see Checking out and releasing objects)  |
             Show Acquisition Hints
             Displays the Show Acquisition Hints preference button (see Vectorworks preferences: Interactive pane)  |
             Show Clip Cube
             Displays the Show Clip Cube preference button (see Viewing a model with the clip cube)  |
             Show Grid
             Displays the Show Grid preference button (see Snapping to the grid)  |
             Show Other Objects While in Edit Modes
             Displays the Show Other Objects While in Edit Modes preference button (see Vectorworks preferences: Display pane)  |
             Show Page Boundary
             Displays the Show Page Boundary preference button (see Page setup)  |
             Show Rulers
             Displays the Show Rulers preference button (see Vectorworks preferences: Display pane)  |
             Smart Options Display
             Displays the Smart Options Display preference button to enable Smart Options Display (see Vectorworks preferences: Smart Options Display pane)  |
             Use Layer Colors
             Displays the Use Layer Colors preference button (see Document preferences: Display tab)  |
             Zoom Line Thickness
             Displays the Zoom Line Thickness preference button (see Vectorworks preferences: Display pane)  |
             Document Preferences  |
             Opens the Document Preferences dialog box (see Setting document preferences)  |
             Vectorworks Preferences  |
             Opens the Vectorworks Preferences dialog box (see Setting Vectorworks preferences)  |
